If I mount 315-70-17 tires on stock rims and don't lift but trim the fenders/(or new fenders) and trim the air dam and anything else that I need to trim will these tires rub with our new wheels or spacers on a 2015 rubicon 4 dr?
seems to me this is the way to go to fit 35's I just am confused as to do I need wheel spacers or wheels with this set up.
so think about this 35's stock suspension timed air dam stock wheels and rugged ridge fender (~ 469 )
will it work or do I have get spacers or wheels?:atomic:
you will rub on your sway bar. You need less backspacing either with new rims or spacers. I run 35's with RK 1.5" lift 4.5" backspacing, 2" bumpstops and I am still close to rubbing when fully flexed in the back. Front I still have some room but not as much as you would think.
