Wondering what you guys are running, This is my daily driver and will travel up to 60mph.
I run Yokahama geolandar a/t-s in a 33/12.50/15. Not sure on the lift, I think it is a 2.5 inch lift installed by the dealer, Im new to the Jeep thing and they said it was required for the 33" install.
I have read that tire pressure can alter your ride, I dont think it is bad, she just wanders a bit at high speeds. Not bad enough to be worried. I think there is 35psi in them at the moment.
THanks for the replies all
Eric
http://www.tirerack.com/tires/tires...004&autoModel=Wrangler Unlimited&autoModClar=
ive heard to lower then as far as 27 to 28.. i have mine at 30.
it depends on the tire and rim size vs. the bigger tire as well.. where you are sitting i would run @ 28 psi. see how this feels for you and check the wear patters.. driving when its lightly raining is best because you can see whats contacting around the wheel and whats not. but again @ 28 psi is normal for 33'
35 might be a little too high. i run 25psi with my 33x12.50r15s on 15x8 wheels on the street.
