1 - 16 of 16 Posts
^^You should never have to run max. Assuming you have aftermarket tires...For 33's you should run about 30-32 PSI. For 35's, 28-30. If your tires are stock, go by your door placard.
If you really wanna dial it in, do a chalk test. See post #54 in the link below.
Highway speed drifting
And here's a visual representation of how the chalk test works...without the chalk. :D
I've got a related question, I have Coursers on my Sahara but one has a hole that can't be patched... long story short, to keep from buying a mismatched tire since the AWT is not available I put my Goodyear Wrangler spare one and plan to buy a used cheapo for a spare. Question is: the Coursers have max PSI of 50, the Goodyear has max of 32 psi. Is that going to be dangerous or ride bad. Don't want to kill myself cheaping over a 150.00 tire. but the next full set i get will be more aggressive tread, so i hate to throw money down the drain because the other three are 60% tread
I started out with the higher pressure, but the steering felt like I was riding on over inflated beach balls. I dropped it bit by bit and settled at 26 psi with a good contact patch and smooth ride.
Every jeep/tire combo is different, you can do the chalk test or experiment. When I went to 35s on my Rubi I tried 18 to 28 psi.
I like 20 for the ride and wear. I've went up to 24-26 to see if fuel mileage picked up, couldn't tell much if any difference, gets around 15 on the highway. I use 8 psi on the trail and redrocks.
Ron
Ron
:eek:
20?
Please, take JYJeep's advice.
1 - 16 of 16 Posts
