I have 35/12.5/15 mt/r kevlars on my 2012 jk sport. What is the best tire pressure in these for daily driving?
For 35's you should be around 28-30 PSI, although that's variable depending on your the tire rating. Best way to find your optimum PSI is via a chalk test.
How to Chalk Tires | eHow.com
Use the chalk that carpenters use in string lines, so it'll transfer well from your tires to the asphalt. Don't buy the permanent chalk...it'll say on the bottle.
I'm betting 25 is going to give you a better wear pattern. My 33s don't even put all the tread on the pavement at 30.
i'm at 28 now and i think i am hitting almost all the tread. i'll try the chalk test and see how that turns out.
