What if any problems would I have if I went from my 17 inch factory wheels to a set of 18 inch factory wheel? Would there be any clearence problems if both sets had factory tires on them. They would be for an 07 Wrangler
Clearance will not be an issue with any factory wheel/tire combo.
However, keep in mind that if the overall tire size changes, your speedo will be off.
This chart may help with a speedometer mod -
Jeep Speedometer Gears at Morris 4x4 Center
You do not change speedo gears in a JK. Adjustments are made through the computer.
If you're moving to another stock wheel/tire setup, a dealer can probably make the necessary change. Otherwise, you can use a programmer like the AEV Procal (or many others to choose from) to make the update:
American Expedition Vehicles - Brute Kit, V8 HEMI, Aftermarket Jeep Conversions, Products, Wheels, Accessories and Highline Kits for Jeeps (TJ, JK, WK, XK).
The overall size of factory 17" and 18" tires is exactly the same. It won't change anything with speedometer or performance.
I don't recommend it though. My 2010 Sports previous owner swapped the factory steel 16" rims for 18" Sahara wheels. By the time I purchased it the tires were worn out. When I started pricing 18" tires, and saw the limited options available I started looking for 17" wheels. I found a set of take-off's with like new tires on them for a lot less than it was going to cost me to by new 18" tires.
When you have the same overall size tire on an 18" vs a 17" rim there is less rubber between you and the road. You get a smoother ride with the 17's, they cost less and you get a lot more options.
