1 - 15 of 15 Posts
What do guys think of Nitto terra grapplers on the moto metal 959 rims?? 295x70x18 tires on 18x9 black rims. Going on a 2011 JKUnlimited, mango tango, with a 3 inch lift. Going to paint the inserts on the rims mango tango. Any thoughts or suggestions?
Trail grapplers are quieter? I might have to check em out. Maybe go with the 35x12.5x18s. I wonder how many miles they're good for. Oh, and what's a droning noise? Thanks
The droning noise is the "hum". My friend has em and it sucks on long trips...simple fix is to turn up the radio. Check out the duratracs, toyo at2, hankook dynapro's to name a few. The toyos are the quietest of the bunch. I have a soft top and when I switched tires to toyo at2, no difference in sound and minimal power loss. Even the e rated versions are quiet.
however.... since your going 18's and 35's you'll have to do your own research as there are a select few that run those combo's. compare the weight of the tires. 10lbs is equivelant to 100lbs in excess load. stay light!
yes...cheaper than the 18's and have a ton of upgrade options. 33-40'tires
15's cheap but no bigger than 35's
16's limited selection of tires
17's more expensive of the two (wheels/ and tires) but you can still manage to stay light.
18's - expensive/heavy
20's - mall crawl
15's no bigger then 35's...WRONG go check out Interco they got sizes up to 44's on a 15" rim
Heres my brand new 37's on 15's
I will say tho, 17's are the new 15's.
Discussion Starter · #15 ·
Ok. Those rims only come in 18". Are there any 17" rims that have inserts that can be painted, that you know of?
1 - 15 of 15 Posts
