Hey guys, I'm in the process of removing a 3" body lift, and will be also getting new tires. I have a 4" suspension lift on also, but the current tires are 35" bf Goodrich. With the 4" lift, should I run 33x12.50x15 or 10.50 width? Also, what tires would you recommend? Thanks
what wheels do you have? back spacing? you can keep the 35's if you add a 1.25 BL
Good choice in removing the 3" BL. I agree with TJspeed. Go with a 1.25' BL and your 35's will work great. 10.5 with is what I would go with, just adjust little if you rub.
I have Pacer 15" wheels. I also have bigger fenders that hang down. Here's a picture
your back spacing is fine you can run 12.5 safely! but yeah just put a 1.25 BL on you'll be cherry :thumb:
