my '93 does not have a lift kit and it does have 30x9.5s as a foot print....there seems to be plenty of space for an up size set of tires......w/o a lift what is typically the largest tires that can fit
That is correct, and you will definately limit your wheel travel off road if you go bigger than that. You will end up with custom bent fendor$........lol.1BLKJP said:Usually without any lift either the 30x9.50's or 31x10.50's are as big as you want to go (without major fender modifications that is)
