1 - 12 of 12 Posts
I have a 94 YJ, and am curious. I know someone who had a scrambler and fit 31x10.5's on it, no lift, little or no rub. Same with his current 2000 TJ. Could I do the same with my YJ, or will it rub like crazy?
31 is very tight, and if springs are old, i wouldn't do it. if you wanna clear them, the quickets easiest way is shackles. it is every yj owners first mod. keep your old ones though, as you will probably be putting them back on when you decide to get a better lift.
What about 30x9.5? I'm not really interested in a lift, to be honest. No need for it around here, and I don't intend to do much wheeling in it.
those will fit w/ no lift and tired springs.
i have 31 10. 5 15 on my 89 and it has no lift at all they work great for street but off road i rub
Yeah, I have a 90 with tired springs. I have 31s on it and they rub off road. They are good on but rub off. I trimmed my flares and am getting ready to lift it too.
My springs arnt to bad still really stiff and Im lookin at getting shackles just to lift i a bit
Discussion Starter #9
Thanks all..I don't know, maybe I'll go with 30x9.5...but I'm not really worried about them rubbing off road if I do get the 31x10.5, simply because I won't be using it extremely often off road.. but then, knowing the roads around here, they'll rub on half of them -.-'
Personally, I would recommend replacing the stock springs if they are worn and flat. If you do mainly on road driving, you will fit the 31s no problem. But expect to get some rum if hitting the trails.
Jeff
With 31s and no lift it won't take "extreme" off roading to rub. Minor stuff will make it rub. Add a couple inches of lift and you will be good.
1 - 12 of 12 Posts
