I have a 1" body lift and 2.5" suspension lift, I run 33s and when I disconnect I have no rubbing. You need to extend the bumpstops.32s will fit with your 2" BB an 1" BL.
but off the road there will be some tire rubbing when disco´d.
i have 32s with 2" BB and 2" BL and there is still a bit rubbing when i full flex.
if you don´t have disconnects you can install some 33s and there will be no rubbing.
