Looking for a new set of tires. Going with 35x12.5 or 315/60.
90% of my driving is city other 10% is highway. I do not do any off-roading. I live in RI and get a fairly large amount of snow and ice in the winter.
I like the look of Nitto Trail Grapplers but sounds like they wear out on pavement and aren't good in snow.
Looking through a ton of threads looks like DuraTrac are the way to go for my needs. Just looking for some input.
Thanks in advance.
I would not run the Nittos for a street tire, great on the rocks tho!
Also, in general a wide tire like a 12.5 is not going to be as good in weather as a narrower tire.
Some folks around here give some street tire love to Duratracs and Fierce Attitudes.
Is it just looks you're going for? If not, why go so wide for snow or street? Looks like you'll be getting wheels too, as the 315/60 is a very wide tire for stock wheels.
I recently pulled off a set of 285/70 on aftermarket wheels, to go with a set of 255/80 Cooper ST Maxx on stock Rubi wheels. Couldn't be happier with the look, the gearing, the handling and the traction.
I like the wider look I recently got my hands on some rims 20x10.
Was thinking about keeping my stock rim/tires an swapping out for winter use but if I could find a good year round tire that has the look that I like I will just keep it on year round.
I like the Toyo ATII and for your application, I would put on the 295/60-20. It's in their XT series so it's a bit more aggressive looking. It's around 1/2" smaller than a 35 but that little bit will pay you back in mileage and winter weather performance. They do have the 35 as well.
Otherwise, throwing wisdom out the window, I would put on the Toyo Open Country RT in 35x12.5x20...
I'm personally putting on the ATII in a 285/75-17 for nearly the same height as the 35's but a more reasonable look. The 12.5's can sometimes look over done to me.
Had mine installed yesterday.
I traded-in my Goodyear Kevlar mt's these tires are one inch shorter and two inches narrower than my 315.70.17's were. They do not fill my wheel wells with a 4 inch lift like the kevlars did. I have around 60 miles on snow pack and ice commuting over the last two days. I actually like the look and performance on winter roads is good so far. I had no complaints with the goodyear MT's however, my jeep usage has changed, I may go larger again some day but I am pleased so far.
