1 - 20 of 47 Posts
Hey hows it going!
I'm looking to get some new tires for my jeep. I have an 05.
I'm looking into the MTR's and hear good things about them.I just have to decide size. Are they good for winter? I live in NE and need some good snow tires.
I wanted to go 33x12.5 (how much of a lift will i need for these to fit?) Are there any good lift kits for under a grand? My other option would be 32x11.5
I was also wondering about back spacing?
I was hoping to keep the budget on the lower side!
Thanks for the help!
Sry about the dumb questions
Thanks!
-Jake
is that NE as in the North East or NE as in Nebraska. I can tell you if its Nebraska to avoid MT/r's like the plague. They do not do well on rain or snow covered roads. The do even worse in mud. I did find that they did OK if it was fairly deep untouched snow other then that they were some of the worst all around tires I have ever owned.
However if you play in rocks all the time I think they would be a great choice.
You need about 3-4 inches of lift to fit 33's. There are many good lift kits for much cheaper then a grand.
Backspacing. You need about 4.25 or more for 12.5 inch tires.
Retired Moderator
no no no...you need 4.25" or LESS...preferably 4" or less...more backspacing means the tires are closer to the body and under the jeep more which means rubbing when turning...in other words any more than 4.25" and its almost guaranteed that you'll rub...i think you mean to say 4.25" or less ;)
scoob is right though, there are plenty of 3-4" lifts for under a grand...good ones too
New Hampshire to be exact.....
Thats why im looking for some new tires for the snow and man do we get plenty of that white crap! The jeeps so light i was looking for some extra traction.
Any suggestion at what I should be looking at? What kind of tread type width and such?
Are there any tires that do really good in the winter weather? Should I stay away from MT's?
Thanks again!
-Jake
the mtr's are a good tire I dont know about the snow since we dont get much here in the desert.
I do know the mtr sucks in mud they dont clean to well
I have a 3 in. teraflex lift with 33's with out rubing
Thanks again!
-Jake
If you want a mud tire that does good on the road then get one that is siped. Like the Cooper STT, Toyo's or MTZ's. BFG AT/KO will do very well in the snow. But not so great in the mud (at least compared to a MT) and will last a long time on the road. I have the Mickey Thompson MTZ and absolutely love them.
BigJeep. Sorry for the confusion by "4.25 or more" I meant more backspace (aka lower number), not 4.25 and higher numbers.
Any word on the toyo mt's? And how'd they handle in snow?
For good snow proformance do i wan't to stay away from MT's? What should i be looking at for tread?
Thx
Jake
Ok i think im going to go for the 32X11.5 and a two inch lift. (any advice on which lift kits are on the cheaper side?
What do you think or should i just go for the 33's and a 4 inch lift?
I am still just a little confused on the back spacing.
What size would i need for 32x11.5 tires on a 2 inch lift?
Does the bigger number mean that the wheels are further away from the body?
thanks again
Jake
Retired Moderator
either setup is fine. if you go with the 2" lift you can go with a coil lift which replaces the coil springs or a spacer lift which is a spacer that goes over the stock coil springs. both are cheap but the spacer lift is cheaper. by the way, the spacer lift is called a BB (budget boost).
whether its 32's or 33's a 15x8 wheel will be fine. or you can go with a 15x10 if you go with the 33's but most people like the 8" wide wheel.
now for backspacing. alright think about the backside of the wheel. now you know that the backside of the wheel has the raised circle in the middle where it mounts on the jeep. (the mounting point where the holes are. now backspacing is the distance from those holes (mounting point) to the end of the wheel (the side that is facing inward when mounted on the jeep) or to the lip or end of the right side of the wheel if we were looking at the jeep from the back and looking at the driver side while they are mounted
most if not all aftermarket wheels for jeeps have a negative offset (because a lot of people buy new wheels for bigger tires and need less backspacing)
so the higher the backspacing 4.5" lets say means that the mounting pad is closer to the street side which means it goes in further to the jeep to be mounted so it is closer in and doesn't stick out as much. less backspacing sticks out more, say 3.5" means its closer to the side that is facing inward when mounted which means it doesn't go in as far under the jeep before it hits the mounting pad so the rest of the wheel is sticking out. sorry so long and hopefully not confusing
refer to this link to help you out
http://www.discounttire.com/dtcs/infoWheelOffsets.dos
Discussion Starter · #12 ·
I just want to thank you for all the help!!! Its much appreciated!!!
I just have one last question or maybe 3 or 4:D
Ok so say I get the TOYO 33x13.50R15. Will they fit on my stock rims? You recomend runing them on 15x8?
I think im going to go with these and get a 4 inch lift. Do I need to buy back spacing or anything else??
I guess that since I'm going 33 I will need a new special tire carrier in the back to fit em?
Sorry for all these questions. Its my first time doing this and i want it to be done right!
The bigger the number means the tire is closer to the body.I run 32X11.50 On Rock Crawlers and the backspacing is 3.75
Retired Moderator
you'll rub for sure. and i wouldn't run them on a 15x8. it is recommended that the width of the wheel be within 4 inches of the tire width. you don't "buy" backspacing lol. you can get some kind of adapter or spacer to fit the tire on the back but the tailgate can bend/crack over time from the exta weight
Retired Moderator
revreed said:
So, let me throw another question in here...
I have a '99 Sahara with the factory wheels on it.
Would the 32 11.5's work with the factory wheel as far as width and backspacing???
if its the 8" wide wheels (i think the saharas have those) then it could work. i've heard that they will work for those wheels but if the backspacing is the same (i think it is) i don't see how they would. i wouldn't do it
Discussion Starter · #18 ·
So if i got a wider wheel would they not rub? So say for example i wanted these wheels....https://www.quadratec.com/products/92800_00X_PG.htm..... what size of them would I have to get in order for my tires not to rub?
Theses are what you use for the backspacing right? https://www.quadratec.com/products/product_search.php?kw=wheel+spacing&submit=Go! (cant you buy the wheel with the proper backspacin already tho?)
Bigjeep im goning to have to start to pay you money for answering all my questions. Thanks again, Jake
Discussion Starter · #20 ·
haha hey i just aprecaite you guys helpin this newbie out!
Now back to those question!!!!
1 - 20 of 47 Posts
