1 - 11 of 11 Posts
do you have 7" or 8" wheels? if 7" then maybe a 9.5" or 10.5" tire would suit you better. if you have 8" wheels than you can easily mount up and run up through 12.5" tires. from a tj person's standpoint the issue with 12.5" wide tires on the stock wheels is more a problem with backspacing and not width - they just will rub without some version of a hub spacer. again, this is a tj guy's view - not sure how it'll affect the yj. make sure you put up some pics when you have it all together :)
chris
Administrator
15x7 or 8 as I recall. Sometimes they marked what they are, on the inside or back of the rim.
Administrator
That wheel is an American Eagle Model 054 5 lug...
It has been discontinued for a while. It came in various widths and backspacing. Just go get it measured at any competent wheel shop.
there not bead locks so you can get a set of non bead locks for like 250.00
1 - 11 of 11 Posts
