Very thing I've ever read has said that you can only fit 33" tires on a stock suspension for a JKU. According to a chart I've found via the interwebs, my 255/75/17 are 32.1". They look like they've got a lot of room for more tire, with non-stock fenders. I'll be putting 2" spacers with it too.
Can I go bigger?
You can... but you'll get rubbing off road if you go much bigger. There's a thread about people running 35"s no lift. 33s are perfect with no lift and just trimming the Air Dam if it catches at full lock.
Check the rear pinch welds also you'll be getting close without trimming and hard enough off-road will cost you a tire
