How big can you go on an unlifted 2002 TJ? will you get any rubbing or unwanted effects from putting on larger tires before getting a susp. lift?
I am thinking of getting something larger and want to know how big i can go before i need to start lifting.
I have an 01 TJ and put 31's on stock steel wheels. I had a slight rub up front at full steering lock but I put a washer behind the steering stops and no more rub.
New wheels with 3.5in back spaceing will eliminate the need for the washers so when i get new wheels i'll take the washers back off
