yes, i will keep stock rims as i can not afford new ones yet. Plus it's a lease so i don't want to go overboard bc i have to return it back in it's original form.33's with stock fenders, 35's if you trim your fenders. It is possible to run 37's on stock setup but I'd hesitate to do that. Are you planning on keeping the stock wheels? If so you will need spacers for the larger tires.
Jeremy
thank you for this.....:welcome: to the Forum..:wavey:
http://www.wranglerforum.com/f27/largest-tire-on-stock-jk-heres-your-answer-142837.html
^^^Here is your answer!!!
Intents and purposes.for all intensive purposes.
Which wheels are you getting?If I go with 33's on stock rims, how wide can I go? Also what size spacers do I need
