Stock BF Goodrich are badly cupped so I replaced with Goodyear. Tire shop says stock shocks are good and alignment is good and can't see why tires are so cupped. They were rotated often.
Is it possible that towing all four down behind motor home is the cause?
Would upgrade shocks help?
If I replace the shocks will I need to have front end aligned?
Thought something was wrong with my steering and noticed that my front tires were cupped... Put them on the back and drove great afterward... Still don't now the cause... Had always had good air pressure
ESP said:
Are you exceeding the max tow amount?
He towed the jk behind something, not towed a trailer. That shouldn't put extra wear on it tho
