1 - 15 of 15 Posts
Will my stock TJ fit 33x12.50r15 on wheels with a 5x5 bolt pattern? The wheels have 3.75 inch backspacing and are 19 mm offset. Will they fit?
The tj is 5 on 4.5. You will need the adapters to make the wheels fit. But since the wheels are already on a 3.75 bs, adding the adapters would put them way out there.
I don't think you will be able to clear the 33's hight wise even with well backspaced wheels. Someone can corret me if Im wrong, but pretty sure im not
Yea that's true. I read over the part that it was all stock. Yea you will need to get it up in the air a few inches to clear those 33's.
I have 31's on my stock 99 and i am staying strictly on road until i get my lift installed. I think 33's COULD fit.........but if you even think bout hitting a bump they will eat your fenders. just what i've noticed
Yes. If you dont do any serious offroading. I run 31x10.5x15 on mine without a lift on stock wheels. I only rub at full turn and im not taking it offroad with that setup cuz i cant not give 'er hell when im off the road. Very mild wheeling should be fine.
Yes second that...mild wheeling is ok with this setup
You'll be fine then:)
And you could bedline instead of powdercoat. Thats how alot of guys on here go and probably what im gonna do when it warms back up
Discussion Starter · #12 ·
I was looking into 31x10.50r15 nitto dune grapplers on the stock wheels. Do you know where I can get some at a decent price?
Discount Tire Direct I know has them.. Just under $170 per tire I think
Another rim option is to paint em.....autozone has rim-specific paints in several colors. That's what I did, and they've held up fine. Prep is key!
Im completly stock, running 31x10.50x15 Duratracs on Mickey Thompson Sidebiters 15x8, i get no rubbing at all, even at full turn. I havent had the chance to take them off road yet though.
1 - 15 of 15 Posts
