I am experiencing a problem with my ’99 TJ, 4.0, with automatic trans, and 127K miles. I don’t think this is related to the problem, but the jeep is towed occasionally by a motorhome, always following the procedure in the owner’s manual. I’ve driven the Jeep about 400 miles since the last time it was towed with no issues.
The problem first appeared this morning while I was on my way to an appointment. After traveling about 5 miles, the transmission started slipping for a few seconds on the 2nd to 3rd shift. The further I drove the more serious the slip became, and not just on the 2nd to 3rd shift but almost all the time, and in every gear. The total distance driven to the appointment was about 20 miles.
After the appointment and before driving it any further, I checked the trans fluid level which was correct, and with no tell-tale odor. Not wanting to risk any further damage I trailered the TJ home. Upon arrival at home and offloading from the trailer, it ran perfectly and shifted just fine. After driving several miles there is still no slipping but there’s a strange noise coming from the general area near the torque converter when idling in forward or reverse gear. The noise seems to disappear in neutral.
My first thought was that the problem is heat related but I’m not getting any visual indications like a check engine light. Transmission fluid cooling is through the factory radiator. I guess I’ll try the obvious first step of fluid and filter change, but I don’t hold out much hope for a fix there. Does this sound like something you’ve experienced, and if it does, what was the solution?
