howdie once more....
Got a question about fender extensions (or flares)
Will a set of tj flares fit on a yj? how do you install them, do I have to drill in the iron of my Jeep, or do they atach to the inside of the flares?
Hope you guys can give me an answer pretty soon, 'cause i can buy a set of fender flares second hand, and don't know how long they will be available, these things go faaaaaaaaaaaast since they cost a lot of euros when bought new.....
Thanx in advance!!!!
Greeeeeeeeeeeets
Zorlac
The TJ's have wider openings front and rear, so you will have to cut the sheet metal quite a bit to get them to fit. I don't think they are any wider though. The reason most people swap them is to fit a larger diameter tire in there without rubbing. They will give you enough clearance so the 31's don't rub anymore.
