I recently purchased a 2003 TJ 4l, 5 sp. I bought it from an older guy. He said the MFS would need to be replaced as the fog light were always on. He said he thought he cut a wire or removed a fuse to turn them off. The green fog light symbol was always on in the upper left corner. If I wiggled the turn signal lever the light would go out but come back on when I released. I replaced the switch and now the indicating light operated as it should but, I can not get the fog lights to work. I don't see any fuses missing from under the hood nor do I see any signs of a cut wire. I tested the fog light connection by the right headlamp and no 12 volts. Any ideas of where to look next?
