1 - 13 of 13 Posts
So I'm looking at purchasing a jeep again after having to sell my yj couple years back. I found a tj that he says the front driveshaft was stolen from it.
I am trading my truck for the jeep and i don't have alot of money to buy what looks to be a 770$ factory replacement part. Could someone tell me what to get that is cheaper so I can get back into a jeep. It can be a custom one a different style it doesn't matter i just want something that works and is relatively cheap cause 700+ is not in the budget at all.
the tj in question is a 99 wrangler 4" lift 2.5L 5speed.
thanks for any help.
Varify gearing in both axles. Before putting in the new shaft. Could get disasterous if the gearing is actually different
Knows a couple things...
While Tom Wood is a great suggestion for a less costly new replacement front driveshaft, also look on eBay and Craigslist too. Just make sure what you buy is configured for a TJ with the 2.5L engine and the same transmission you have. The driveshaft length varies by engine and transmission type, and its diameter varies between one made for a 5-speed vs. the smaller diameter driveshaft required if the Jeep has an automatic transmission.
Hey Jerry, I just broke my front driveshaft. Must have bent it on a rock last time. Today, it twisted and broke in half. If I buy a used driveshaft from eBay, should I have a driveahaft shop check it out or can I put new I joint in and bolt it up? My understanding is that Spicer's 5-1310x u-joints are the way to go - correct?
Yep the Spicer 5-1310x would be a great choice of u-joint. I can't say if a used DS would need to be checked out by a driveshaft but a good eyeballing of it & working of the u-joints by hand to check for slop would at least give you a good idea if bolting it up is a reasonable thing to do.
Heck send the eBay seller a message & ask him its condition... most are honest if they receive a direct message/question like that.
Also, ask the seller if the DS is from a TJ with an automatic or manual transmission. They have two different diameters with the driveshaft from an automatic being much skinnier in order to clear the transmission pan.
Is the smaller diameter DS weaker or stronger than the standard? If it's equal or better, I will take the additional clearance, but need something strong in case I ding it again. Mine is a manual and the wall thickness of this shaft is fairly thin material.
I'd only go for the larger diameter driveshaft from a manual. Manual transmissions can cause a lot more shock-loading of the drivetrain so the stronger larger-diameter driveshaft will be a desirable thing. You definitely don't need the additional clearance the smaller diameter DS would provide.
Tom Wood is of course widely known for making an outstanding product, but he is even better known for his nearly incredible pre and post-sales support. I have been running his driveshafts for at least 10-12 years and couldn't be happier with them.
Ha! Maybe the guy who stole my DS broke it and needed another so he stole another one! Sometimes i think the zombie apocalypse needs to come because of D-Bags like these thieves.
Great thing about Tom Woods is his products are great and you can call him up and talk directly with him. I love that.
1 - 13 of 13 Posts
