1 - 20 of 211 Posts
delicate %$^&*@ flower
In light of the recent discussion of lifts, we all felt a thread with ONLY lift kit reviews in it would be a good source of information.
AzTJ posted a great lift review in the Your Lift thread and hopefully he will be posting it up here shortly.
Here are the rules.
1. This is a review of YOUR lift. No second hand reviews.
2. Try and stay in the format Az used to ease the exchange of information.
3. This is not a discussion thread.
4. Oh and please post up some pictures.
Any post but lift review posts will be deleted. If you have a question about a specific lift you can always PM the person or start a new thread.
Please be fair in your reviews. This lift sucks is not a review. Also, those reading reviews, remember this is personal opinion based on personal experience. If your lift is already reviewed, review it anyway. Ratings and reviews are always better when there's more than one opinion to draw from.
Thanks to everyone for participating.
Drives by Braille
My Lift...
LIFT: Rubicon Express 4.5" Super Flex w/ 3.5" Springs Substituted
SHOCKS: Rubicon Express Twin-Tubes
SYE/CVD: Advance Adapters HD SYE Kit & Tom Woods CV Driveshaft
TIRES/WHEELS: BFG All-Terrain 32x11.5x15" on Eagle Alloy Series 135 15x8"
Likes: I really liked how complete of a kit I got for the price(included the sye & shaft). It performs VERY well on the larger rocks that I play in(once disconnected). Having replaced all 8 control arms, I feel very confident that I won't be damaging anything soon. The on-road manors are much better than stock and I can still take highway mountain turns at 65mph and not worry... it still grips like stock. The 3.5" springs are much taller than they say. I probably have gotten 4.25" out of them and I seem to still have close to 4" of lift after almost 2 years and a hard top on all the time.
Dis-Likes: The twin-tubes are rough riding... not bad on decent roads or highway, but once you hit bumps, you really tell how poor they are. Spend the money and get some good RE Mono-Tubes, Ranchos, or OME shocks. Another thing I don't like is the grease fittings. The ones on the lower control arms are between the axle tube and the control arm so using a grease gun with a flex hose is necessary and small fingers help. The front adjustable track bar is kinda dinky and the heim joint on the frame end needs lube quite often to keep the noise down when turning.
Would You Recommend: YES! For the price and performance, and completeness of the kit, I'd highly recommend it for anyone looking for a very nice weekend-warrior setup running 32-33" tires. The only things I'd like to change are the front and rear track bars. The kit is probably a little more extreme than what I actually do with it, but I like being over-prepared. :cool:
Picture(s):
Lift: Full Traction Long Arm kit
Springs: 3" Teraflex coils
Shocks: Old Man Emu
SYE/CVD: Teraflex extreme short shaft kit & Tom Woods CV driveshaft
Tires/Wheels: Interco Trxus M/T 34x12.5R16 on stock rubicon rims
Likes: This kit was built very well and is very heavy duty. I have landed very hard, numerous times, on the belly skid and done nothing more than scratched it. I also like the rear tri-link set up because it allows removal of the rear trac bar and also trusses the axle itself. The truss is completley bolt on too which is a huge bonus if you ever decide to swap axles or something like that. The two major things that I am most happy with in this kit is its strength (everything is thick and heavy duty) and the flex that it produces. The shocks are the best I have ever used on any vehicle. They ride smooth on the road and highway but also do what all cheaper shocks dont do, soak up bumps. These things make it ride beautifully. Even around turns, they dont sink like normal shocks usually do which gives the Jeep a very stable ride. The coil springs were substituted for 3" coils only for the purpose of lowering the vehicle to get a better center of gravity and because 6" of lift (coils that come with the kit) is just unecessary for my tire size. But the spring rate on the tera coils do make it ride nice as well and do great while off road. The spring rate seems to be a little soft but they have yet to sag.
Dis-Likes: There is little I have to say about the kit that I did not like. To do any work on the trans or t case the entire skid must be removed which is a little annoying. I have also found that the zerks in a few of the ends arent accepting grease anymore but those are cheap and easy to swap out and its probably my fault they got gummed up anyway. The exhaust has to be reworked to clear some stuff too but if your going through the work of doing long arms then that shouldnt slow you down. The coils are a little soft and thats about it. Everything else has been good.
Recommend? : Absolutley. It rides better than stock and has been a killer kit. For someone that wants the very best for their dd and something that can also keep up with any other suspension out there, custom or not, this is the kit for you. It will ride like a dream with a good set of shocks like the ome I run and impress the crap out of you off road.
Pictures:
Rough Country 4" II lift kit
This is the entire lift kit, nothing mixed and matched that did not come with the kit. Same tires, before and after the kit.
Kit includes : RC 4" coil springs, RC lower control arms, transfer case drop kit, sway-bar links, RC Hydro 8000 series shocks, drop pitman arm and bracket, hardware..
Cheaper than competitors (in that height), good experience, fairly complete, it gets u riding 4 inches higher, looked quite nice and shiny in the box, comes with 4 small stickers and 2 big window sized stickers.
Coils:They have rubber coating which does not peel or flake off like paint. Very thick and muscly.
Lower control arms: still have paint on them with very little rust, they are also greasable which increases bushings life, location of grease fittings makes them very easy to maintain.
Tcase drop kit: 2 square tubes (1 per side), not couple washers like some of the other kits. Still no signs of rust or paint flaking.
Sway bar links: Solid good design, very reliable.
RC Hydro 8000 series shocks: None
Drop pitman arm and bracket: Better alternative than having to drill a big half an inch hole in the stock already weak bracket.
Hardware: Any bolts and nuts are included in this category. It's good they were all here.
Dis-likes:
Coils: Because they are very hard, they cannot flex and make a nice bouncy ride. At first when i installed the rc kit. I measured almost 5" of lift increase in the front and 4.75 in the rear. Well about half a year after installation (no offroading either) i noticed my rig was definitely sitting up higher on the rear end than the front which made me take measurements. Yup, it's true, the front was lower than the rear but also the passenger side was lower than the drivers side. Those measurements back then were 4.25" lift on the rear drivers coil, just under 4" for the passenger and about 3.5 for the fronts. The rubber coating was ripped on spots when i took it out of the box.
Lower control arms: Very bad design. They use rubber/plastic cylinders as bushings which cannot bend or flex at all increasing the load on the axle and frame control arm brackets. Next, the location of the grease fittings puts them in the way of rocks fallen trees or any other obstacle on the world.
Tcase drop kit: None
Sway bar links: Paint is flaking exposing rust underneath.
RC Hydro 8000 series shocks: They rode hard from the start till the second i ripped them out of there. I flipped the rear shocks over with no change. I am not saying factory sports car hard, i'm saying racing car hard. Again rust on the body and plenty on the piston rod.
Drop pitman arm and bracket: uck, I dont know why they spend their time even designing this combo. It's junk but yet costs just a bit less than their 4" track bar. I have some bump steer. The bracket and the dropped pitman arm are both 100% rusted.
Hardware: NOT A SINGLE BOLT WAS STAINLESS. They all rusted through.
Over all this is a basic lift kit that will get you riding 4" higher but you will hate every part of it without throwing extra cash in there. Riding in this thing is just horrible, it flexes horrible comparing to stock because of the suspension being so much harder from springs to shocks and yet it leans a lot more. In other words you need good traction to flex this thing and at least some good shocks to make ride good.
Recommend? No Save ur greenies and spend it on something that you can enjoy.
Pics
My Lift...
LIFT:4 Wheel Customs - TJ/LJ/Rubicon 2.25" Complete Budget Boost Kits
SHOCKS: stock
SYE/CVD:stock
TIRES/WHEELS:stock rims with cooper wild country 31x10.50 muds
Likes: it does what it says: 2.25'' of lift. its cheap, and a great place to start because you can keep them in when upgrading your lift.. the ride feels the same as stock, but probably because im on the old stock shocks still. also like that its an actual 2.25'' lift because most 2'' bb are actually 1.75'' to 2'' and this is a definate 2''. 1/4 inch might not sound like much but hey, every bit helps right? especially when your cheap! i dont plan on going too much farther with this jeep, as its a 4cyl and i want to get a rubicon next year. my wife wants this one, so i think 2'' will suit her fine.
Dislikes- instructions made things seem easier than they really are.. theres some better install instructions online that go way more into detail than what ships with the parts. not too much i can dislike about it, i mean its a 2.25 inch lift that you dont need any other parts for besides the lift spacers, and rear bump stops.
Would You Recommend: YES! for anyone looking for a BUDGET boost this kit is the way to go.
Picture(s):
Lift: skyjacker bb
shocks: sky hydro 7000
tires: 31x10.5 dunlop mud rovers (some crappy kellys filling in for the ones i popped)
Likes: love the mud rovers, cheap and very effective on the trail. love the hydros, bouncy as hell on the road, but great articulation off it.
dislikes: not big enough!!!!
My Jeep: 2004 Wrangler Unlimited
My Lift: Rubicon Express 3.5" Super Flex Short Arm. (Adjustable Control arms, rear upper and lower, front lower) Front RE adjustable Track Bar.
SHOCKS: Rancho 9000x adjustable with in-cab controller
Disconnects: JKS Quicker Disconnects
SYE/CVD: None - Stock driveshafts
TIRES/WHEELS: BFG A/T KO's 33x12.5x15" on 15x8 Steel Soft 8's
Likes: I purchased the RE from Offroad Toy Store. The basic kit came with: 4 fixed length lower control arms, 3.5" springs, extended bump stops, extended front brake lines, rear track bar bracket, rear extended sway bar links, transfer case lowering kit (not used), RE gen 2 front disconnects, and DT3000 shocks. The thing I really liked is that OTS offered upgrade options to the basic kit. It was $120 to upgrade the 4 control arms to adjustable, $180 to upgrade to the Rancho 9000x shocks, $120 for the front track bar, and $50 to upgrade to the JKS Discos. Shipping was free and they threw in a Rancho 5000 steering stabilizer for good measure. Total cost for the kit and upgrades was about $1,250. I installed everything in one day with the help of a friend who had installed the same kit on his Jeep a few months before. Instructions were very clear and easy to follow. Took it in and had it aligned the next day. (01/14/09 current price, w/upgrades = $1,340)
I have since upgraded the rear upper control arms to RE superflex adjustables, added JKS front bar pin eliminators and the in-cab controller for the shocks. I have adjustable RE superflex upper front control arms and rear JKS bar pin eliminators sitting on the bench waiting to be installed.
Two years later I can say that this kit has held up exceptionally well. I'm very happy with the performance both on and offroad. This is my daily driver so road manners were important to me. The ride is much better than stock and the adjustable shocks allow you to tune the ride to the road conditions. Offroad, it performs like a champ. Lots of flex and plenty of clearance when combined with the 33" tires. Overall, I got 4.5"s of lift and because I have an unlimited, I did not have to drop the transfer case or do a SYE/CV drive shaft conversion. I've added a winch, Oil pan skid, bumpers, tire carrier and a 33" spare and have only experienced 3/4" of sag in the springs in over two years.
Another thing I like about this kit is that it is upgradable to a long arm lift if I choose to do that in the future.
Dis-Likes: It is hard to come up with anything I dislike about this lift. RE has exceptional customer service. When the bushings went bad on my rear upper control arms, they sent me new ones for free (even though I was not the original owner). The biggest pain in the whole install process was getting the barpins installed in the shocks. And then the shocks made a clunking noise from sliding around on the bar pins. I'd suggest that anyone installing this kit spend the $50 on JKS front and rear bar pin eliminators from the beginning. It will save a lot of time and wasted energy.
Would You Recommend: YES! I would highly recommend this kit (more so when combined with the upgrade options) I did a lot of research before purchasing it and have no regrets. It was easy to install (I would highly recommend that anyone who chooses to lift their Jeep do the install themselves) and my experience with RE customer service was great.
Picture(s):
LIFT: Rubicon Express 4.5", 1 '' body
SHOCKS: Rubicon Express mono tubes
SYE/CVD: Tom Woods CV Driveshaft
TIRES/WHEELS: 35x12.5 Dick Cepeck Crushers on 15x8 Black steelies
Likes
: The RE kit came with absolutely everything I needed, and eveything fit like it was supposed to. RE seems to underrate their lifts, a 4.5'' RE is more like a 5'' lift from other companies (or maybe I'm just a litle crazy:cool:) With a 1'' body my 35's fit with no rubbing at all and plenty of room for flex. I also went with an OME steering stabilizer.
Dis-Likes: The ride is not very smooth. On the highway it's fine, rides straight and handles well. But at speed any major bump/pothole (and there's a lot in NYC:mad:) will make you feel like you need a new spine. The kit was a little pricey.
Would You Recommend: Yes. RE makes a great product and I've got many trail hours and highway hours on the kit with no problems so far.
These pictures are a year old already, I'll try and post some better ones!
[URL=http://g.imageshack.us/img141/backtirehg8.jpg/1/
LIFT: 4" RockKrawler X Factor Plus
SHOCKS: OME Nitrochargers
SYE/CVD: Stock( for now )
DISCO'S: RockKrawler Quick Disco's
TIRES/WHEELS: 31x10.5 cheapos on stock wheels
LIKES: RockKrawler knows how to build their stuff, everything that came with the kit seems indestructable, Zerk fittings are easily accessible, but don't come with kit, the company apparently plugs them saying that they do not need to be greased because the bushings are captured. Easy to install, however, the rear cradle for the tri-link rear end has to be welded to the axle. Kit is complete with SS brake lines, front adjustable track bar and bracket, drop pitman arm, springs that seem to have given me more than 4" of lift, fully adjustable upper and lower control arms, and Rockkrawler's abuse proof warranty on all parts. Customer service was great M-F, non-existent on the weekends :mad:, even when they initially sent me the wrong kit, they rectified it within days.
DISLIKES: EXPENSIVE, Rear cradle had to be welded in, no shocks with kit, instructions are lacking some information, and when you do some serious offroading, half the jam nuts or attach bolts for the control arms come loose and have to be re-torqued.
WOULD YOU RECOMMEND: Yes, This kit is for us who like to constantly tinker with their rigs, if you are looking for a lift that requires nothing after you leave the trail, than this lift is not for you. With the OME nitro's and this particular lift, the ride quality on the trail/road is phenominal.
I Have photos, but cannot seem to load them, it keeps saying they are too big
Rubicon Express 4.5” Long Arm with the Trilink rear upgrade.
RE Monotube shocks
RE Rear driveshaft
JKS Quicker disconnects
Pros:
The lift is great. It rides good on road and works great off road. The quality is top-notch. I ruined both rear shocks by mounting the shock brackets too high and bottoming them out, RE replaced them even though it was my fault. The kit comes with everything you need including brake lines and pitman arm. Some people say they don’t like the radius arm setup, but I really like it.
Cons:
The instructions are a bit lacking but if you have any mechanical experience you can figure it out. As with any long arm, you have to cut off the frame control arm brackets. With the RELA there is a little welding. I wouldn’t do the Trilink again, it is more money and it puts a control arm right where the exhaust should be routed and makes it hard to come up with an exhaust that fits. The RELA kind of expensive but you get what you pay for!
Lift: Full Traction 3” Economy kit
Shocks: Full Traction springs
SYE/CVD: Advanced Adapters SYE and CV shaft
Tires/Wheels: BFG All Terrain 33x12.50 on Alloy 15x8’s
Likes: This kit was very cheap ($500) and allowed me to go bigger cheap and put 33’s on my Jeep. This brought me into a new level of wheeling. The soft springs also flex well. The combination of the soft springs and shocks valved specifically for the Wrangler make for a soft street ride too.
Dis-Likes: The problems started with the install. The instructions were like something a guy in China used a Chinese to English dictionary to write having never seen a Jeep before. The instructions also skip over the fact that the front drive shaft will hit the trans-skid if it’s left in place. Removal of the skid and replacement with a Warn skid was my first upgrade.
Upon taking my first ride, I felt the rear trackbar bracket hit the underside of the body while driving over a bump. The bracket is very tall compared to other brands. I replaced it with one from Rubicon Express to fix this issue.
When adding the weight of my hardtop, rear tire carrier and 33” tire, the rear springs began to sag. I had to add a 1” spring spacer to the rear. The Full Traction front trackbar is cheap and would flex as I turned the wheels. I replaced it with one from Skyjacker. After adding a SYE and a Dana 44 in the rear I needed adjustable control arms, because the kit still used the stock ones. I got them from Rusty’s Off-road and couldn’t be happier with them.
Recommend? : N0. In the end you get what you pay for. The kit is cheap in every way. It’s been 4 years now and I’ve replaced almost everything but the springs. It comes lacking many thing other kits include. Save your money and get a more complete kit with tougher parts and you’ll save money in the long run.
The picture is right after the lift was installed.
03 Rubicon
LIFT: Clayton 4" SA (Short Arm)
SHOCKS: OME Long Travel
TIRES/WHEELS: 33 Bighorns on Black Powder Coated Moabs
Likes: I really like the strength of this kit and the craftsmanship. The Johnny Joints make this kit flex like crazy and the street ride is awesome too. This is my DD & wknd warrior.
Dis-Likes:
I have nothing that I disllike about this kit. Only had one issue with is and that was with the Front Trackbar rubbing the diff cover. During the installatrion I noticed that the Air Locker relay was in the way and might get crushed, so moved it and zipped tied it back.
Would You Recommend: YES!!!! worht every penny for a dependable no B.S. lift kit. This kit was made for abuse and it sure takes it.
LIFT: 4'' prpcomp lift, 4 lower control arms
SHOCKS: procomp es3000s
SYE/CVD: stock/ 1'' tc drop
TIRES/WHEELS: 35x12.5 bfg mts on 15x8 Black steelies
Likes: a cheap and complete lift kit.. looks good
Dis-Likes: a majority of it.. very harsh ride, handling isnt very good, poor flexibility
Would You Recommend: smaller tires, better shocks
LIFT: pieced together:: Front: 2'' procomp coils, jks acos, jks trackbar, jks discos :: Rear: jks acos, RE trackbar mount, jks adjustable swaybar endlinks :: 1.25'' jks bodylift
SHOCKS: RE monotubes
SYE/CVD: stock/ mml for vibes
TIRES/WHEELS: 33x12.5 procomp mts on 15x8 eagle alloy rims
Likes: not many people have the SAME setup, i pieced it together and know the quality of parts on it, handles well, flexes good for stock control arms..
Dis-Likes: not cheap, not complete (yet) and not tall enough
Would You Recommend: get a complete kit.. i didnt want to save up.. i took it step at a time..
3 Inch Teraflex Suspension Lift
Jeep- 2002 Jeep Wrangler Forrest Green
Lift- 3 Inch Teraflex Suspension Lift
Tires- 32 inch All Terrains (I Want My X Terrains Back... :(
Likes- I asked the makers said it would make the ride more stiff but it is a lot softer and i love it. I have a lot of flexing space. Very easy to put on. i did it in my friends garage.
Dis-Likes- Came with crappy cheap stearing stabliser bar which cause me to get massive death wabble. Oh and not quite big enough :D
Coming Soon- 2 inch Body Lift!
My Lift...
LIFT: Fabtech 6" long arm lift
SHOCKS: Fabtech dirtlogic monotubes (upgrade from what came with kit)
SYE/CVD: Stock Rubicon
TIRES/WHEELS: Procomp 35x10.5x15" on XD series aluminum 15x8"
Likes: This lift is very complete and includes everything you need up front to get it back on the road when the lift is done. It rides very nice, has a lot of flex and so far (been on for over 2 years now) holds up very well to the abuse I've given it. No spring sag (yet anyway) and I get zero tire rub with 35" tires. The dirt logic monotubes are a tad stiffer than what stock feels like, but give excellent performance and feedback on the trail. A worthy lift for TJ's.
Dis-Likes: High dollar lift. Keeps you with the stock skid plate. It's not the easiest lift to install. Not many Jeep folks have them (As Fabtech primarily makes truck lifts).
Would You Recommend: Yes. Performance wise, it compares to the other great lift packages out there and is a very complete kit. If you want a full 6" of lift without additional BL and can find it priced to compete with RE, go for it. You will be happy.:)
Lift: Full Traction 3 inch lift
Shocks: Pro Comp shocks (bought seperatly)
Tires/Wheels: BFG All Terrains 32x12.50 on Alloy 15x8’s
I like the way it rides, soft, but not too soft. It was cheap ($550), and came with quick disconnects, although I bought the Pro Comp shocks seperatly. It was fairly easy to install if you know what you are doing, I suggest to have someone who knows what their doing install it.
Dis-Likes: Non so far, I've had it for over 5 months now. There was one problem, it may be the installers fault (my jeep buddy) or the lift, I am not sure. He installed it, and I got the death wobble. I went to my mechanic friend who pretty much took off the whole lift and put it back on correctly. It runs great now, just make sure you do it right the first time.
Recommend? : Yes, it is cheap and I am glad that I did it. It looks great, and besides for the death wobble, I am happy with it. Ever since I fixed the death wobble, everything's been great (knock on wood).
3 inch F/T Lift with 32 inch BFG A/T's
ROCK KRAWLER 5.5 X-FACTOR longarm
LIFT: ROCK KRAWLER 5.5 X-FACTOR longarm
SHOCKS: rockkrawler... later replaced with procomp with internal bump stops
DRIVESHAFTS: Phx Rack & Axle (PRA) thick wall and CV
TIRES/WHEELS: 35" bias baja claws... later went to 38" tslx but I'd only recommend going that big if you are stretching the wheelbase... otherwise its too big of a tire.
Likes: Local shop is dealer/installer and involved in testing. Answered all my question before, during and after purchase and install. Support is A+ from RK. BEST flex of any longarm kit. mostly because of using only a single arm from frame to axle on passanger side. Optioned to have extra long travel shocks for maximum flex/droop. Upgradable to approx 10" stretch for not a ton of money. Good fair price.
Dis-Likes: Get some good coil/spring retainer clips to hold your coil in at the bottom of the bucket. the retainer clips hold the front coils in but I've had the clips break a few times and spent the day pulling my hair out every time the front end would flex and drop a spring. The rear coils are kept in place mostly by the shocks limiting rear flex. The procomp shocks we bought have internal bump stops so there is no concern for overextending them. Be sure to use bar pin eliminators in the rear otherwise the shocks will pull out from the tub when they reach max flex and you'll also lose a coil when that happens (see 1st picture). I'm in the process of upgrading to coilovers in the front and eventually in the rear and stretching with the RK stretch kit
Would You Recommend: of course. its awesome. if I were to buy another jeep or given the opportunity to help a friend select parts for a jeep build I would definately go with this RK lift.
LIFT: stock control arms with 3.5" RE coils HYBRID
RE1600 front adjustable track bar.
RE extended rear swaybar links
teraflex rear trackbar relocation bracket
1" body lift
1" motor mount lift
SHOCKS: Rancho 5000 for lifts between 2.5 and 3" of lift (sounds shortish but they were perfect)
DRIVESHAFTS: stock driveshafts... * i have 241OR and they don't use slip yokes so you may want a slip yoke eliminator and aftermarket driveshaft
TIRES/WHEELS: 35" MTRs... later went to 35" bias baja claws (bias makes them longer lasting in the rocks)
Likes: pieced this together with my spare money on weekends. stock control arms flex amazingly! I used this setup for years all the way till I finally saved for a RK long arm kit. The shortish shocks worked great! limited flex so the stock arm bushings wouldn't overwork themselves and still offered tons of flex as you can see in the photos.
Dis-Likes: ZERO complaints. kept up with all the "hardcore" wheelers. WHen I finally did switch out everything for the RK kit the stock control arms were pretty much done... the metal was cracked and splitting and the bushings were toast. But that just made it flex even better :D
Would You Recommend: of course. its awesome. :D was a perfect setup for learning to wheel.
My Lift...
LIFT: Full Traction 3" Economy lift
SHOCKS: Rubicon Express Twin Tube shocks
SYE/CVD: N'A
TIRES/WHEELS: BFG All-Terrain 33x12.5x15" on MT Classics 15X8
Likes: Was an easy install. Price was good. I purchased RE shocks prior to lift. Ended up with more then 3" of lift.
Dis-Likes: where to begin. The front track bar is garbage. There is no way to even describe how poor the quality of it is. The rear track bar bracket was a p.i.t.a. to mount and must be re-tightened all the time. The RE shocks are very stiff, if your into having your stomach in your throat every bump, then these shocks are for you. The end links are complete junk. The pin for the disconnect ended up wearing the hole bigger and I ended up putting a 3'8"s bolt threw it to stop the banging noise, so they are no longer quick disco's. The steering is very loose now, the ride sucks, I had to instal a 1" spacer up front because the springs sagged 1 month later. I used the tc drop that came with the kit and it still has vibes, had to butcher my console to get the shifter into 2nd, 4th, 6th and reverse.
Would You Recommend: Not really. If your looking for a cheap priced lift, then you'll get a cheap lift. I am debating whether to upgrade all the other parts minus the springs, or take it out and go back to a BB.
1 - 20 of 211 Posts
