here in the northeast the days are getting shorter and the weather colder/wetter, so i wanted to get this task done. had never done an auto trans change (drive mostly manuals), but did some research and decided to give it a try.
picked up a filter at the dealer for $18, and 4 qts of atf+4 fluid. started at 4pm, finished at 530 pm (same day!).
let me add some observations and suggestions:
1) please wear clothes you don't care about.
2) for those who have said that changing this fluid/filter is like changing motor oil/filter, i say "no way". there is a filter and 4 qts of fluid, but that's about the only similarity. there are about 15 bolts to remove/clean; a pan to remove and strip rtv off of then wash out with brake cleaner; the filter is torx bolted on, please don't strip the head!; put down lots of absorbent protection surrounding your pan, you'll probably need it.
3) i read many posts about doing this with the skid plate on. i tried, but realized things would go much better without it. it was the right thing to do.
the plate is only held on by 4 bolts. once dropped, it had clear access to the whole pan.
4) wear disposable gloves
5) the torx is a 25
6) use enough rtv, you don't want a leak.
7) i had a little scare, when i had it done i decided to take a quick spin. i started it up, shifted through the gears, then put in reverse-NOTHING. my stomach dropped some. i gave it a minute or two, then put in reverse again, and it moved!
the drive was short, shifted nice. no leaks, but will check again before bolting the plate back on.
Nice job.....one of those things I want to do but haven't.
Why did you use rtv instead of a factory or aftermarket gasket?
thx. to my knowledge it comes from the factory with rtv. that's what was on it when i dropped the pan, as expected. the service/parts dept said this is standard as well. i believe there are aftermarket gaskets, but i just wanted to stick with what jeep used.
Correct the factory uses RTV but a gasket is fine to use.
