So my mechanic buddy told me that when I go to 35's, with the proper gearing I should get better mpg that I am now with 31s and 3.07 gears, which is about 15 mpg.
I called BS but was only about 90% sure. Am I wrong?
Vendor
It ultimately depends on how you drive. You probably get into the throttle pretty hard with your current set-up which leads to poor mileage. The new gears will keep you from putting your foot as far into it, but you'll also be running higher RPM's and be turning a bigger tire/more rotating mass/bigger contact patch/more friction. If you take it easy on the skinny pedal you can gain some MPG's. Good Luck!
-Ryan
Whatever mileage you are getting now with 31s will be reduced with 35s and probably considerably. Going from 35s back to 33s netted me about 2 MPG.
