I have a 2000 TJ 4.0 with 87k miles on it that I've owned since March:
A few weeks ago I had this issue with it not starting. When I turned the key, it would beep for about 0.1 seconds and then no beeping, no dash lights, no sound, no cranking, nothing.
I replaced the ignition switch and actuator pin and everything was working great again.
One month later, same problem. Tried replacing just the ignition switch again and nothing happened. Still not starting up. Didn't change the actuator pin but the tip didn't appear broken as many people have complained so I left it as is. Replacing the switch did not fix it. But then my brother in law said maybe its a loose wire connection. So I kind of jiggled and secured the wires connecting to the ignition switch. And just like that, the thing was running within 2 minutes.
That was two weeks ago. I've had no problems since then. Now today, as I'm getting in my car at the mini mart near my work this afternoon, the stupid thing is acting up again. Won't start. Same exact symptoms.
I played with the wires, tried to hold them in tight. I took the ignition switch off and put it back on, and I took out the lock cylinder and put it back into place to see if maybe I had reinstalled something incorrectly.
I've already used my 1 free tow from AAA and the thing is currently sitting at the gas station/mini mart down the street until I get off at 5. They generously agreed not to tow me.
Please help! I need to get this thing running. Ideally I'd like to be able to get to work tomorrow. Thanks for your suggestions.
