Tj Softtop conversion
1043 6
Anyone have a write up on the Tj softtop conversion to run full doors with soft top?
A TJ soft top will not fit on a YJ, the windshield angle is different and the mounts are all wrong for the door surrounds.
Two answers no doesnt fit but yes can be made to fit.. you need a tj cage and have to modify the window frame yjs are square.. your yj doors wont seal the doors are smaller then the tj.. in order to put tj doors on theres some drilling.. I think jp magazine did a right up on it
Trying to make a tj top work on your yj is an absolute waste of time. If you want a full top, get a supertop. They are pricey, but not as pricey as it will be to mod your yj to get a tj top to fit without leaking profusely.
