Have 1998 wrangler 4.0 with the ax15 tranny (five speed) which bolt do i take out to check my fluid?
On the driver side of the tranny in about the middle pull the upper plug out and if oil doesn't come out then stick your finger inside and see if you can feel oil.
Yep. And it should be right to the level of the plug hole. I don't know why, but too many people try and feel lower than that to see if there's fluid, in the case of it leaking.
