1 - 14 of 14 Posts
Hey everyone,
I am new to the forum and have recently purchased a TJ 5 speed 6 cylinder. I had a YJ a long time ago but I sold it due to rust. I have got an issue probably a common Jeep problem so here it is.
So I cannot remember the "normal" for a jeep transmission. While running in neutral I get some clutch or transmission chatter. When I press in the clutch the chatter goes away. Release, chatter comes back. To my knowledge if it was the clutch release bearing wouldn't the noise be apparent while the clutch is pressed. Is this a throw out bearing or is a "normal" noise for a the NV3550?
The NV3550 is noisy. From what I understand, the noise is normal. Mine sounds like it has marbles rolling around in it while in neutral with the clutch out. Haven't had any problems.
If you search the forums you'll find a lot of people have this "issue."
Knows a couple things...
Although the nv3550 is noisy, I would possibly suspect a throwout bearing.
Throwout bearings don't spin/make noise when the clutch pedal is up. They only start spinning when you're stepping down on the clutch pedal and they go to work to lift and hold the clutch disk away from the flywheel..
What he said.
My NV3550 is noisy in neutral also.
Either my TJ was abused pretty bad or the NV3550 sucks. Feels like shifting a noodle(horrible index) and the sychros are slow/suck.
OK cool I may just get a free check to make sure wouldn't be a waste of time to know. Yeah the noise is only apparent when the clutch is up. Only got a few more weeks before I lose the 3 month or 3000 mile guaranty from the douche dealership.
Just an update if anyone is searching the forum with a similar issue:
Took my Jeep to my mechanic and the noise was normal. He inspected the clutch and tranny and all were in great shape.
Did you notice if you could hear, what sounds like, a bolt head or something hitting the bell housing when you push the clutch in. Mine has the marbles/whirling sound like yours, but when I push in the clutch it tick, tick, ticks to a stop until things stop turning.. I cant figure it out.. runs and pulls fine.. any help?
don't remember hearing anything like that, but I will listen when I get back into it.
I replaced my ax15 with a nv3500 and the noisy neutral really blew my mind when I heard it. It was brand new...replaced the fluid with a different brand...no change. Just noisy for four years now.
1 - 14 of 14 Posts
