Hi guys , my jeep won't start
Ran through the forum and found the on off key trick to show error codes
Error code 42 appears.
I think fuel related cause..
firstly can't hear pump when ignition on
Squirt juice into throttle body and its fires up for a sec
Checked fuses and relays - all ok
Bridged fuel pump relayed at fuse box ( connection 30 and 87 as per relay ) and no fuel pump noise
Ran volt meter at fuel tank loom - 12 volts is being recieved at plug that goes into fuel pump
I'm assuming it's a bad fuel pump but have not dropped tank yet .. New to the wrangler scene , common problem ?
Any other tests before I start tank drop ?
Thanks
Thanks
