So you ziptie and cut them off when finished? Would be awesome if someone made bolt on clips that would hold it out of the way, but I guess that solution works as well.I push the swaybar up & tie the disconnects to the bar with a couple zip ties. The friction in the bushings will hold the bar up
Ooooh...I like theseTake a look at RC discos, you mount a bracket to your frame to hold the links when disconnected
Yep..I push the swaybar up & tie the disconnects to the bar with a couple zip ties. The friction in the bushings will hold the bar up
Those rc's r a great idea! Wish I would have gone with those but my jks discos have never failed me yet.Ooooh...I like these
Jeep Sway-bar Quick Disconnects
Are they a quality item (as good as JKS?) Also, will they work on my 2" teraflex coil leveling kit?
They say up to 2.5" lift so they should.Ooooh...I like these
