I have a 97 TJ 2.5 every time I start it hot or cold it rev's to 1800 for a minute or so then slows down to tick over What would cause this. Thanks Rob.
Possible vacuum leak? Any whistling or hissing sounds near the intake?
Knows a couple things...
Guessing vacuum leak or a dirty IAC (idle air controller). A dirty IAC can be fixed by spraying at least 1/3 of a can of throttle body cleaner into the throttle body while the engine is idling. The engine will die when you get enough cleaner into the IAC but just restart it and spray some more. Raising the rpms will cause the cleaner to bypass the IAC. The IAC is what provides all of the engine's air when you're not stepping on the gas pedal. If the IAC is dirty it can stick and provide either too much or too little air causing too high or too low rpms.
