Need some help here, I can only afford to do one project right now and, as you will see from the pics, the torque boxes need to be replace where the tub mounts and the transmission skid plate is also in need of replacement. I need some opinions on which to do first. Both will cost about $2000 each so I have to do this at different times. As you can see in the pic of the torque box, the rust has taken over and it is cracking so that seems to be the more pressing issue, but I would appreciate any input or advice you wold have on prioritizing these repairs. Thank you.
