1 - 9 of 9 Posts
Playing with the thought of flat towing my YJ behind a 94 s10 blazer on about a 7 hour trip. Blazer is a 4.3 L Auto with tow package and I think it's rated to tow around 5500 lbs. YJ weighs in a tad bit over 3K. Any thoughts? Am I thinking myself into some trouble here? I don't have a problem with the trip taking longer, having the take breaks, etc or the ride being a bit bumpy..just don't want to get into an unsafe situation.
Thanks all..
you will be fine. My family has towed with our 2000 Chevy Astro numerous times. The trailer was a 1997 Palomino pop weighing about 3000#. the Astro is basically the same vehicle, same engine and i believe very similar frames. in the van there was always 5 people, a dog and enough camping gear for about 2 weeks. The 4.3 is also a torquey beast and you shouldn't have a problem. Have fun =)
Thanks for the reply nvr. I've been going back and forth on whether to use this setup or not, but it's the best one given my circumstances. I also have an 01 Dakota, but it's only a 3.9, not as much torque and no tow package/hitch (tow bumper only). I've used it to tow the heep short distances but cringe at the thought of towing long distances with it, so a buddy offered me up to use his Blazer if I wanted.
Thanks again for the reply.
Are you planning on wheelin at your destination? Make sure you carry extra univ. joints and axle shafts.
towing a jeep
]Playing with the thought of flat towing my YJ
I did that and lost the rear drive shaft somewher in calif.
I also tore-up the muffler, cut a fuel line, and the cable for the speedomiter.
It bent the shaft that comes out of the back of the T-Case. broke the unit that covers the slip yoke.
Left part of the drive shaft U-joint attached to the rear end.
I did not know this happen until the end of the 150 mile trip.
Be very careful and read the tow instuctions ahead of time.
Boy did that hurt my wallet.
How the heck did towing cause you to lose the drive shaft?
yeah, howd you lose the drive shaft? and then not know till the end of your 150 mile trip!! :rofl:
Discussion Starter #8
Wow, now that's a war story. Did you leave your t-case engaged?
No, not planning on doing any wheeling...just moving to a new place.
drive shaft vanished
I have no idea. Someone told me that the T-Case could have poped into gear when I hit a bump, or something????
All I really know is it cost a bundle to fix, and I didn,t know when it happen.:deadhorse:
1 - 9 of 9 Posts
