1 - 9 of 9 Posts
Hitch Mounted Motorcycle Carrier - 400Lb. Capacity
has anyone tried this? The bike I need to move is about 400 lbs. Its a Moto Guzzi, not sure if it would fit in the rack anyway. My trailer is way too big, it' 6 1/2 x 10. The Willys gets sucky gas milage anyway.
Anyone have any bright ideas? Dont really want to buy another trailer.
Going to pick up bike in L A, then back to Texas.
Thanks.
ExtremeTerrain.com Sponsoring Vendor
Thanks.
I've seen that the max tongue weight for a 2 door is 200lbs. I think it's listed in your owners manual. I don't know how the Jeep would handle with 400+lbs or tongue weight, but it's something to consider. Good Luck!
-Ryan
You could but without airbags inside your rear coils or heavy duty rate rear springs it's going to wander all over the highway and your lights will be pointed 6 feet off the ground.
FYI
Uhaul won't rent a trailer if you intend to pull it behind a soft top. Don't know why, but the won't.
Hard top - no problem
FYI Uhaul won't rent a trailer if you intend to pull it behind a soft top. Don't know why, but the won't. Hard top - no problem
Correct I just rented one a month ago and as soon as she asked what vehicle I had, she then followed up with, "I hope you don't have a softtop on do you?"
1 - 9 of 9 Posts
