Hey, just picked up a Reese class 3 receiver and a curt T wiring connector #55124, the problem is I don't understand what the 4 pin connector hooks up too to allow me to operate trailer lights.. Or of there's something missing. I'm aware of towing and trailer hookup as I tow everyday for work. But extremely unfamiliar with wiring set up, could anybody give me a heads up on what I may be missing..?
I just looked over the instruciton sheet, seems pretty clear. Remove the driver side tail light, then carefully disconnect the tail lite wiring harness, the connector kit then plugs into either side of that disconnected wiring harness. What's missing is telling you how to feed the 4 pin wiring connector down and out to the hitch.
Here is a video from etrailer that should help you out.
Tow Ready Custom Fit Vehicle Wiring for Jeep Wrangler 2011 - 118416
Your trailer will have either a 4-pin, 5-pin, or a 7-pin plug. Do you know which you have on your trailer? The 4-pin is the standard, it just covers running/brake lights. The 5-pin is more commonly used by boats as the additional pin is for the reverse lights that locks a hydraulic brake while backing. A 7-pin is used if you have a brake controller installed. They make adapters for your vehicle to step down from 7-pin to 4 or 5.
Most RVs and larger trailers will come with electric trailer brakes and and you should then install a brake controller and the additional wiring harness for that controller. The wiring harness you have is not for electric brakes.
Hope that helps.
