Towing recommendations
3973 25
We have always had a camper. Looking for one I can safely tow behind my short wheel base Willy's Wheeler edition JK 2015 model. Must be under 2000lbs. Plan to use a sway bar set up. Want a pop up or small trailer with AC. Anyone have experience towing with a vehicle like mine?
1 - 20 of 26 Posts
I'm also in the market, so I attended an RV and Camper show outside of Chicago last weekend. I've got a JKU Sahara with the max tow package, so at least I can hit 3500 lbs. Most of the pop-ups are in the 2500's range, but I just checked Starcraft's website. Their Starflyer series has 2 models (8' and 10' box). Those both come in under 2000 lbs GVW.
Google Coleman Colorado. Right up your alley, but scarce as hen's teeth.
I don't know of any pups under 2000 lbs. even my stripped down graphite w/10' box and no options comes in at 2300 lbs.
Have you looked into a [email protected] or something similar?
Going Shopping today. The problem with the teardrops is they only accomadate 2 people but are hard sided and many under 1500 lbs. There are pop ups with listed dry weights of well under 2000#. I had planned to tow the Jeep behind a Motorhome, but too many things can go wrong with a Motorhome and it will cost $2000.00 plus to set up with new equipment to tow the Jeep (if you include some kind of braking system). I will post what I find as options. With my short wheel base I will likely use a sway bar at the least, trailer brakes would be a strong boost in safety. I was so surprised at the low towing capacity of my Jeep with it's V6. But then I never intended to tow with it when I bought it.
Tow package
Paul, what did your tow package include. I am wondering if I should add a transmission cooler or if the Jeep already has one.
OP, I would look into a teardrop. We have a [email protected], that has a 10x10 tent that attaches to the side . That is where the kids sleep and we also use it as a changing room.
Camelback trailers are a nice option for a 2 door Jeep. Don't push the weight limit with a short wheel base rig like a 2 door Jeep. Can you say death ride? Towing is ok but stopping and going down hill it will push you all over the road if you get to heavy.
Looking at a 2008 Fleetwood Cobalt. Dry weight 1500 #.
Here are the stats:
Length (travel/camp): 12′ 10″/16′ 9″
Width (travel/camp): 6′ 10″/incl. steps, 7′ 5″)
Height (travel/camp): 4′ 1″/8′ 4″
Unladen Weight (public scale): 1440 lbs.
Unladen Tongue Weight: 135 lbs.
GVWR: 2300 lbs.
It has an AC which probably adds 200#.
Looking at a 2008 Fleetwood Cobalt. Dry weight 1500 #. Here are the stats: Length (travel/camp): 12′ 10″/16′ 9″ Width (travel/camp): 6′ 10″/incl. steps, 7′ 5″) Height (travel/camp): 4′ 1″/8′ 4″ Unladen Weight (public scale): 1440 lbs. Unladen Tongue Weight: 135 lbs. GVWR: 2300 lbs. It has an AC which probably adds 200#.
I have an '07 Graphite- the cobalts slightly bigger brother. love that pup!! Does it have the one piece roof or a seam lengthwise down the middle? It's counterintuitive but you want the seam- due to some pretty big issues with the one piece roof delaminating. Not sure what came on the cobalt models.
I have a 2014 2dr rubi.
I've been towing for years, mostly with trucks.
I just sold my Diesel crew cab.
On average I tow a trailer twice a week.
I tow a 15' enclosed trailer. Single axle.
The box is 6' wide, 6' tall and 12' long.
Empty it weighs 1,350lbs.
It's your typical work trailer.
I've pulled it in rain, ice and snow.
I've pulled in 30mph winds going over the blue ridge mountains.
I've done this in snow when trucks are pulled off to the side.
I know all the warnings and what people say about the short wheel bass and all.
IMHO these newer jeeps with 3.6 pull great if you stay within your limits.
I'll say this. I would rather pull this combination with my jeep over any other vehicle.
With the jeep I feel every detail about the trailer. For me that's key.
Hope this helps.
We just bought an Aliner Ranger 12. Its 15 ft. long and weighs 1600 lbs. We will be picking it up this wkend. Ive got a 2015 JKU Willys with max tow,3.73 gears,TF 1.5 in coil level/lift and 315/75/16 Duratracs. I am replacing the 4 pin with a 7round as the camper has ele. brakes. The Ranger has two burner stove,ele./propane pw frig,11 gal. water tank, a/c,heat,small sink and sleeps 2-4. You can set this thing up in under 5 min.
I was meaning Turtleback trailers. These guys if you want to camp off the beaten path.
Best Off Road Camping Trailers exclusively at turtlebacktrailers
You had a diesel and you would rather tow with a Jeep? You lost all credibility with me. Nothing tows like a Diesel truck but I will cut you some slack if your a Ford guy. My Ram 2500 with a manual stick is towing machine. If its rolling it towing. With the weight you don't even know anything is behind you. I don't want to feel everything the trailer is doing which includes pushing the Jeep around. Weight and torque for the tow rig is key. In a good tow rig you should not feel anything the trailer is doing. It just ride along behind like it is one solid vehicle. You can tow with a Jeep no problem but it sure helps if you know what your doing. Too much speed and that trailer starts pushing you better know what your doing. People get comfortable towing at speed and when you need to stop or slow for an emergency see what happens. Just ask Bruce Jennier. When towing my 10K pound off shore boat with my Ram it stops faster with the boat and trailer then without. Triple axel trailer with disks brakes all around drags the truck to a stop. Be careful out there.
I was meaning Turtleback trailers. These guys if you want to camp off the beaten path. Best Off Road Camping Trailers exclusively at turtlebacktrailers You had a diesel and you would rather tow with a Jeep? You lost all credibility with me. Nothing tows like a Diesel truck but I will cut you some slack if your a Ford guy. My Ram 2500 with a manual stick is towing machine. If its rolling it towing. With the weight you don't even know anything is behind you. I don't want to feel everything the trailer is doing which includes pushing the Jeep around. Weight and torque for the tow rig is key. In a good tow rig you should not feel anything the trailer is doing. It just ride along behind like it is one solid vehicle. You can tow with a Jeep no problem but it sure helps if you know what your doing. Too much speed and that trailer starts pushing you better know what your doing. People get comfortable towing at speed and when you need to stop or slow for an emergency see what happens. Just ask Bruce Jennier. When towing my 10K pound off shore boat with my Ram it stops faster with the boat and trailer then without. Triple axel trailer with disks brakes all around drags the truck to a stop. Be careful out there.
I was specifically referring to the newer jeeps ability pulling LIGHT TRAILERS.
With that being said, who cares about a diesel?
The threads focus is not about trucks.
IMO, with this light combination feeling the load is a huge plus.
OP, the jeep light trailer combo offers another nice factor.
It's super nimble in tight spots.
Keeping on topic, staying within the limits, jeeps are more then capable for towing.
Hope this helps.
Was following up the post from above regarding selling his Diesel and prefers towing with his Jeep. Not buying it. Some day we will have a JK diesel but Jeep is so slow the market. With Diesels it is hot about HP but Torque. Nothing pulls better than a Diesel. In AZ we see a lot of them that come out of Mexico. The new Diesel used in other Jeep products here is excellent compared to the old one still used in Mexico.
When I was pulling heavier trailers, up to 10,000lbs, no question a diesel kicks ass and I too like the Cummings.
Now, If I could pair that with the Alison. SWEET
How about this.
If we ever do get a diesel jeep I'll buy two.
I'll give you one and we can go get a beer
and argue about it? :)
1 - 20 of 26 Posts
