1 - 11 of 11 Posts
Would it be ok for me to tow a 78 trans am on a dual axle flat bed trailer with my 2014 jku with max tow
The short answer is no. You are going to be well over the rated tow capacity of your JKU. Your dual axle trailer is most likely equipped with a 7 pin harness while your Jeep is equipped with a 4 pin. This is your first clue that tow vehicle isn't equipped to pull the trailer.
Define OK? Tow it how far, and over what kind of terrain? Either way I'm pretty sure you'll exceed the towing capacity.
I wouldn't do it.
It sounds like it would be way over the 3500lb rating of your jeep. You might want to consider using another vehicle with a higher tow rating.
1 - 11 of 11 Posts
