Any suggestions?
My problem ended up being that the 4 wheel parts misplaced one of my sensors when they switched my stock wheels/tires out for my new set.mrkeefer said:i had the same problem. I would check the psi agian in ALL the tires(spare inculded) air up to atleast 40psi again in ALL tires. that should reset the light, then run at whatever psi you want. if that dosen work you can always get the AEV procal and lower your psi in the ecu.
it is possible you have a bad tpms sensor or missing one. do yo have aftermarket tires/wheels, full size sapre?
