Long story short, I have death wobble and am going down the check list of things it could be. I was able to get the nut and bolt out of the top bracket of the track bar but the bottom bolt is stuck. I mean stuck, like break tools stuck. Need advice on how to get it out. I've used a bfh, a bf impact wrench, nota.
Heat . Get the torch on it and warm it up....carefully.
Plus 1 on the heat. I once changed the shocks on an old truck and the bolts were rusted tight. I heated them with a propane torch and finally got them looses.
The bolt is probably rusted to the sleeve that is inside the rubber part of the trac bar mount or the bolt is rusted to the captive nut.
