I need a new mount for the frame side but can't find one anywhere. Can anybody help
it's easy enough to make that. no need to buy something fancy. get some flat 3/16" plate, cut & shape to fit, drill holes, bolt in place, tack weld in place, remove track bar, go nuts with the welder. shouldn't take more than a couple hours.The first pic is where it is rusted through.
TRACK BAR MOUNT!!!!!
I've got one you are welcome to for the price of postage. I cut them off the frame very cleanly when I do a shock outboard job. Had I known they were in need I would have saved the other 20 I just tossed in the scrap pile from other outboard jobs I've done.The rest of the frame has been undercoated
What is an outboard job and do you have a pic of itI've got one you are welcome to for the price of postage. I cut them off the frame very cleanly when I do a shock outboard job. Had I known they were in need I would have saved the other 20 I just tossed in the scrap pile from other outboard jobs I've done.The rest of the frame has been undercoated
depends on what position you weld things in, and where you end up positioning your axle.When you outboard your shocks and do a spring relocation,Do you need two decrease your rear spring height so that the jeep sits level?
