I'm having problems with the front track bar install on my 01 Tj. The slot in the bottom of the axle side mount doesn't line up with the factory hole so there isn't enough clearance inside the boxed area for the nut and tab. Any thoughts or solutions?
A local fabricator drilled and lined up the holes with a 1/2" thick piece of steel. Hope you're still not sidelined...
