Wrangler Forum banner
Thinking of replacing my trac bar as well as both upper and lower ball joints.. Trying to eliminate DW on my 08.. Suggestions on either an adjustable track bar or solid one?.. Only do minor off roading with it being my daily driver..
Thanks for any input
Brett
Death wobble is normally caused by wollard out track bar bolt holes. Due to the bolt being smaller bolted than the holes. Eliminate that first.
I had a good case of DW. My JK has a 3 inch lift and adjustable trac bar. I first installed the Northridge grade 8 bolt kit with the correct sized bolt torqued to 125 ft/lbs.
To my dismay, the problem was not solved. I have the lifetime mopar warranty and took it to my dealer to diagnose the problem. They installed upper and lower ball joints on both sides, new pitman arm and a tie rod end. Problem fixed, $100 bill, Thank You Very Much!!!
