1 - 20 of 21 Posts
Hey all - the last couple of days I have been having a traction control issue. Tonight was the worse it has been. It has only happened to my as I pull out of my gravel driveway onto a blacktop. No tire spin, but my traction control kicked in and cut power to nearly nothing. I didn't realize it and shifted into second and it nearly died. I shit it off and restart it as I was putting along the blacktop and it did it one more time then settled out and ran fine after that. When this happens, they traction control light comes on while this is happening.
Anybody have any thoughts!
Reactions: TX6.5guy
Maybe a wheel speed sensor?
Sent from my SM-T550 using Tapatalk
Are there any ways to determine if that is the problem and which one it may be?
Had the issue again this AM and this is what I did and the result. I pulled out of my driveway and the TC light came on and it stated to bog down or lose power. I reached down and turned off TC and it seemed to fix the lose of power issue, but shortly after that, the ABS lite came on as well. After about 2 miles, I reached down and turned TC back on and all lights went off. I am perplexed. I will have do some research on the speed sensor and see if that makes sense.
@Cride, check for codes. I believe they indicate which sensor is bad.
Reactions: Cride
If it turns out to be a wheel speed sensor you may be able to get it fixed under warranty. I got a letter in the mail, saying they extended the warranty on them and another one that has to do with brakes just can't exactly remember what atm.
My understanding is that this method will not provide the ABS codes. I stopped by Autozone to have them read the codes for me, but they said their scanners do not read ABS codes either. They said they do rent a scanner that does.
You can have the computer read them off for you:
Check JK Codes
1. Insert key and turn the ignition On-Off-On-Off-On
2. The codes are given in the odometer read-out.
Here's the procedure and code list.
https://www.quadratec.com/c/reference/jeep-wrangler-jk-diagnostic-codes-and-how-check-them
I wasn't aware of that. I found some suggestions on an old post from another forum.
"Innova 3150 or 3160. $191 and $220 on Amazon. They should work on your jeep abs system. "
There was also mentions of the possibility of bluetooth readers that come with paid apps that might be able to do this. I couldn't find a model that guaranteed they had this capability.
I have a bluetooth adapter that was $8 off Ebay and the Torque phone app that I think I paid $15 for. It will read everything.
I also have the superchips Programmer which reads all the codes.
Discussion Starter · #13 ·
Well I was finally able to get the codes checked using the key method. It flashed U1418 or Implausable right wheel distance signal. Now, based on a little research, I think this is wheel speed sensor related, but not sure if it front or rear. Anybody have any suggestions?
Discussion Starter · #14 ·
So, as mentioned above, I did pull codes last night and I get U1418 so right side issues. Not sure how to figure out if it is a front or rear.
What is concerning me is the loss of power when it acts up. It really bogs down for a few seconds. This typically happens when first starting the Jeep up taking off the first time. It will bog down and kind of feels like something is binding, then after a few seconds it restores power and everything seems to go back to normal but the ABS and track control lights stay on. They will even go off after a bit of driving. I have also found that if I hit the track control button while it is bogging down, it will immediately restore power.
Anybody have any ideas?
The bogging down and binding feeling is the traction control system kicking in and doing its thing because of the issue your having with a wheel speed sensor. It's retarding power and applying brakes as it's supposed to. With a bad wheel speed sensor, the vehicle thinks that wheel is slipping/losing traction when it isn't. Unfortunately I can't tell you which sensor it is. If you get the sensor fixed, these symptoms will go away.
Reactions: Cride
This guy is absolutely correct.
Reactions: Cride
I did some more digging. It appears that U1418 should be for the rear sensor.
Did you also get a C102B? That should confirm right rear sensor.
Discussion Starter · #18 ·
Thanks for the feedback.
The U1418 is the ONLY code I got.
Discussion Starter · #19 ·
This is exactly what I figured it was, but I hand't really seen anybody else comment about the lose of power.
Discussion Starter · #20 ·
One quick (dumb) question. I assume that when it say right side, it means right side as you are setting in the jeep and not right side as you are looking at the jeep from the front. Can anybody confirm?
1 - 20 of 21 Posts
