Your owners manual recommends against the use of a tow dolly. There's an apparent transfer case lubrication problem with the rear wheels on the ground but the front wheels on a dolly. They recommend either 4 down or trailering.A tow dolly is probably the most economical method of towing a vehicle. Anything else is going to add a lot of weight and cost a heck of a lot more in fuel.
Thanks, I didn't know that.Your owners manual recommends against the use of a tow dolly. There's an apparent transfer case lubrication problem with the rear wheels on the ground but the front wheels on a dolly. They recommend either 4 down or trailering.
Yeah that's actually really good to know!Your owners manual recommends against the use of a tow dolly. There's an apparent transfer case lubrication problem with the rear wheels on the ground but the front wheels on a dolly. They recommend either 4 down or trailering.
This is definitely true. There is 1 way around that tho. If you disconnect the driveshaft at the rear axle you can't dolly tow all day. If you aren't doing too many trips this may be a good option. If you're loading and unloading a lot re-Bolting up the shaft can become tiresomeYour owners manual recommends against the use of a tow dolly. There's an apparent transfer case lubrication problem with the rear wheels on the ground but the front wheels on a dolly. They recommend either 4 down or trailering.
Even though I have read that and think I might understand, I also know that folks have driven Jeeps all over the place with no front drive shaft installed without issues....kind of makes you wonder what the difference would be.Thanks, I didn't know that.
I dont see how thats similar at all? Am I missing something? The Dolly is bad because the T-case is being "spun" while not being lubricated. Spun by the back shaft. Pulling the front shaft while driving in RWD does not change any of that.Even though I have read that and think I might understand, I also know that folks have driven Jeeps all over the place with no front drive shaft installed without issues....kind of makes you wonder what the difference would be.
I think he was comparing having a jeep on a tow dolly to driving a jeep with the front driveshaft pulled. In both cases the rear output at the t-case is spinning and the front output is not.I dont see how thats similar at all? Am I missing something? The Dolly is bad because the T-case is being "spun" while not being lubricated. Spun by the back shaft. Pulling the front shaft while driving in RWD does not change any of that.
I know a lot of the tow dollies aren't wide enough, but the one I rented was plenty wide enough for 12.5 inch wide tires. I only have 10.5s on my jeep, but I had more than an inch clearance on both sides of the tires.Anywho......I think the bigger issue with tow dolly and the OP is, how the hell would it fit? lol. My 35" arent gonna fit on my tow dolly at all. Not even close. lol
Yeah but on the tow dolly the jeep is not running and the t case is not being lubricated properly. With no shaft in the front and driving that is not an issue.I just took a 4000 mile trip to California/Arizona and back last month. I had the Jeep on a tow dolly the entire way. I just disconnected the rear driveshaft from the pinion yoke, taped the u-joint, and bunjee corded the shaft up out of the way. I re-connected and disconnected a few times during the trip whenever I wanted to go wheeling. It wasn't a big deal and I got faster at it each time I did it.
What he said. Just get a tow bar set up, some magnetic lights and a brake system. I tow mine all over the state like that.There are many of us that tow four down. It's less weight to drag, easier connects and disconnects, less parking issues for a trailer (when you're off Jeepin)....just a much more simple setup.
We have a 16' Clark trailer with ramps,....bet I haven't used it twice for Jeep haulin....projects, yes!
So you're saying that in order for the oil pump in the transfer case to function, it needs power from the motor, not just the rear driveshaft spinning?Yeah but on the tow dolly the jeep is not running and the t case is not being lubricated properly. With no shaft in the front and driving that is not an issue.
I think you missed the point. The engine running has nothing to do with the tc getting lubed. The engine is not running when towing 4 down either. The problem is when the front yoke is not turning, but the back one is.Yeah but on the tow dolly the jeep is not running and the t case is not being lubricated properly. With no shaft in the front and driving that is not an issue.
I did in fact miss half the point because I miss read a post also. I thought it was lubed only when engine running so I learned there. Never considered flat tow personally because of my thoughts on the engine needing to be running. Figured flat tow was just as bad. I was under the impression the only way to safely tow with out pulling shafts was flat bed/trailer.I think you missed the point. The engine running has nothing to do with the tc getting lubed. The engine is not running when towing 4 down either. The problem is when the front yoke is not turning, but the back one is.
If that's the case, how does the transfer case get lubed in jeeps that are running unlocked with manual hubs?I think you missed the point. The engine running has nothing to do with the tc getting lubed. The engine is not running when towing 4 down either. The problem is when the front yoke is not turning, but the back one is.
