1 - 1 of 1 Posts
Currently in the process of changing my clutch. Decided to take off the t-case first to make moving the tranny easier plus I want to reseal the t-case cuz when I did the sye it leaks a bit between the cases. Removed the 6 nuts holding the t-case and separated the two but what I believe to be trans fluid started coming out so I pushed back together. No good cuz I just put redline in less than 2 months ago. Did I separate the two in the wrong spot? Will that drain all my trans fluid If I pull the t-case all the way off? any input is greatly appreciated
1 - 1 of 1 Posts
