Replacing the radiator in my TJ and wrecked the cooler lines. They looked like crap anyway and wanted to replace anyway...problem, are the metal bent a dealer only item? I am having trouble finding them....can I use a heater type hose and route away from engine heat? what have you guys done?
I replaced mine with transmission cooler lines, rubber ones, from Napa. I did not replace the ENTIRE line, but cut out some of the metal line and installed the transmission hose with hose clamps. It's not a high pressure line.
