1 - 20 of 24 Posts
hey whats up guys so i finally got the sound away happened to be a sensor i think it was the crank position sensor ,so now i connected the trans the right way and still nothing got a couple of mechanics to take a look at it and they said the trans is bad.i already been thinking about some options i just wanted you guys help me make the best choice.
i was thinking changing from auto to manual * i already know that i need piot bushing , clutch , pressure plate ,the trans,clutch pedal and slave cyinder.iam not sure if the computer changes though,Any parts im missing? if i plan to do this swap which is the best trans to go with ?
or just get the same trans i have now.does anyone know the name of the 3speed 92 trans i have?
Discussion Starter #2
does anyone have the vacuum diagrams for the straight 6 4.0 with autotrans i want to know what are the two vacuum lines that i have to connect
ax15 trans
there's more than two vacuum lines, can you be more specific
opps i meant the vacumm diagram for the auto trans there are two vacum lines that go up to the firewall, but thanks i figured it out allready. And the name of the trans is a TF999 - TorqueFlight .thats for the auto .I cant seem to find rebuild kits for this trans either.
ax15 would be the manual to use for a swap from auto to manual.-
Discussion Starter #6
what parts will i be needing if i do this swap?do i have to change computer ecu?
i think the computer won't matter, going to a manual.
the ax 15 has a plate in the middle, and has two halves seperated front to back. the peugot is seperated in two halves from left side and right side.
Discussion Starter #12
yea that would been totally sweet hey doodler it happen to be the knock sensor making the noise. i am not sure what to do right now i was thinking of changing from auto to manual but i cant seem to find anyone selling ax15 around here i tried the tristate area already. and if i do find someone there selling it for 450 . a lil to much. I found a rebuild kit on quadratec for my auto
the only problem is i wouldnt want to install it and still have the same problem.
have you checked craigslist? that would be my first place ide check. ide stick with auto trans since ide want to drive asap. with stick youde need more parts. get it driveable and then later when time/money are there convert it to stick.
Discussion Starter #14
yup thats where i been checking at couldnt find anything, i took my trans to a couple of places and they said they can do it for 400 , but my question is can i use the rebuild kit and a new tc will it work again?
i dont know. without seeing trans and tc in person i just dont know. from previous threads i believe you damaged the tc or pump but sometimes hands on is the only way to diagnose. the best i can do is give you some info but you need to post pics of trans input shaft looking straight in and tc where it splines onto input shaft.
generally speaking if the trans worked before it should work without a full rebuild. just replace the broken parts. if youve never rebuilt an auto trans ide say leave it to someone else. too many things need to be splined, sealed,clipped, and compressed perfectly or you might not have any gears at all.
Discussion Starter #16
okay i think the verdict is going to be to change to manual, i know i will need more parts but thats not to much of a problem besides i always wanted to learn manual . meanwhile iam going to keep the autotrans on the side and fix it up so i can use it for my future 360. I found a guy selling the trans and the other parts for $200 . Iam not sure about the clutch he is looking for it, most likey get this new with the kit. this ax15 is coming out of a 89 Comanche . so is the flywheel and pedals . my question is will the pedal work for the wrangler? from pictures i think it could work but not to sure. i think i might also need a different flywheel i looked at the flywheel on quadratec and this one seems to be missing teeth but yet again it came out of a Comanche cant be to sure.
Discussion Starter #18
Anyone see anything off?by the way will the output shaft change that connects to the tcase? does anyone know what wire harness is on there already on the pic?
Discussion Starter #20
am looking for a clutch kit yet it tells me the yr of89 commaches had the peoguot trans , do you guys know if this is the ax15 ? on what yr ranges can i get the clutch ?
1 - 20 of 24 Posts
