Is there an easy swap or what is involved swapping from 5-speed in a 95 wrangler with a 2.5 to a auto. Have a bad left leg and 5-speed is really not good in woods or where I off-road. p.s. hate to shift.
Not sure if you would need to swap the pedals. You will need a shifter. Cable shifter floor mount would probably be easiest. If you go with a stock transmission that was originally installed in that year such as a 32RH or a 30RH you need to keep in mind axle gearing as those were 3 speed trannys. You need to check into the ECM part of the swap as well.
A forum community dedicated to Jeep Wrangler owners and enthusiasts. Come join the discussion about reviews, performance, trail riding, gear, suspension, tires, classifieds, troubleshooting, maintenance, for all JL, JT, JK, TJ, YJ, and CJ models!
