1 - 11 of 11 Posts
Tore open my transfer case tonight to start my SYE. I think the last guy that was in there applied the RTV with a hose and high pressure pump. Entire filter body and area around oil pump were filled. Anyway, noticed that the skirt of metal around the pick up tube port is cracked off. Again, last guy basically caulked it place with RTV. The O-ring does seat all the way in, but should I be worried enough to replace it? Can't image there's any substantial pressure there, with just a push in fitting.
It is not a pressure issue it is if air leaked in there the pump won't draw ATF for lubrication so transfer case is starved for lube
I would not use a cracked pump housing or a cracked intake tube
Motorized toy collector
That is exactly where mine broke when I did my SYE.
I was told not to use it and buy another one.
So, that's what I did. Found it on Rockauto IIRC.
x2. :happyyes:
First place I looked, couldn't find it there!
Or go to you pull it and get a used one that you inspect for cracked input
Then pale sure you install properly and carefully aligned or you back where you started
Childish impatience prevailed, and I assembled the unit in the wee hours. It's still on my bench, and I found pumps for $45-$60. I'll check out ebay too. I'll order one tonight and tear it back open. Thanks guys.
There is an old and then a new improved model on those 231 oil pumps I think they are interchangeable and the newer style saw supposed to pump more or be more reliable so it was considered more desire able
Anything has to be an improvement over what I had going on. Between that crack, and the over abundance of RTV, i can't see how any oil was moving aside from splash effect. Bearings were in better shape than I expected after cleaning it out. Any idea how to distinguish between the old/new pumps? First guess would be model#, but those are often reused after changes are made.
1 - 11 of 11 Posts
